Last visit: 2026-09-21 - 22:11
Calendar sync problem with JollaRSS Feed
Yann
smile Posted 2015-11-24 - 11:10
Generally speaking the calendar sync with Jolla is OK. I do have problems with recurrent events starting and finishing during DST periods (day light saving time) . Outside the DST period the event time 1 hour ahead.
For instance, an event starts the 20th of October 2015 and finishes the 12th of July 2016, DST finished on 25th of October and starts on 27th of March. Between October 25 2015 and March 27 2016, this event is 1 hour ahead. Before and after the time is OK!. No problem is the event is not sync with Memotoo. Thanks in advance for your help.
smile Posted 2015-11-26 - 15:55     Subject: Re: Calendar sync problem with Jolla
Hi Yann
This problem is not only with Jolla Phone but also with others phone.
Some phone do not manage correctly the DST with recurrent event... So stop this recurrent event when the DST change, and create one that start the DST change.
