Last visit: 2026-09-23 - 08:19
Not able to sync between BlackBerry BlackBerry and memotooRSS Feed
michanne
smile Posted 2006-11-26 - 20:39
I can sync from handheld to memotoo but not the other way. Funambol version is 3.0.7. I have tried every combinatioin possible -- multiple times and it still does not work. Please help. Thank you
10 Replie(s)
smile Posted 2006-11-26 - 21:26     Subject: Re: Not able to sync between blackberry and memotoo
Try again, I will log connexion and I will see what happen
michanne
smile Posted 2006-11-26 - 23:18     Subject: Re: Re: Not able to sync between blackberry and memotoo
Thank you,
I just did.
smile Posted 2006-11-27 - 18:47     Subject: Re: Not able to sync between blackberry and memotoo
Can you delete your sync information ( https://www.memotoo.com/my-account-sync-history.php) and try again, because I have see nothing in log files ...
michanne
smile Posted 2006-11-27 - 20:17     Subject: Re: Not able to sync between blackberry and memotoo
I am not sure if you meant delete the data --I don't see a way to delete a log. I did delete the contacts from memotoo (I have a backup). The log says my last sync was: 2006-11-27 - 20:02:23 (G.M.T. +1) but the contacts on my blackberry are not in memotoo. So I clicked "in two ways" in memotoo and tried to sync again. This time the msg on my bb (funambol) says "Sync failed. unable to open connection"
smile Posted 2006-11-27 - 23:28     Subject: Re: Not able to sync between blackberry and memotoo
Sorry I didn't want you delete you contact but just sync information (by clicking on "in two ways") ...
To undertstand where is the problem, can you:
1) add a contact on your blackberry and sync
2) add a contact on Memotoo and sync
Tell me when you have do it, I will see log files ...
michanne
smile Posted 2006-11-28 - 00:21     Subject: Re: Not able to sync between blackberry and memotoo
Gotcha now...
I sync'd it and the contacts that were in BB were added to Memotoo but the contact I added to memotoo was not sent to BB.
smile Posted 2006-11-28 - 08:51     Subject: Re: Not able to sync between blackberry and memotoo
Very strange ...
Can you try a new sync without do changes -> I have changed th modifcation date of "New contact" and normally it will be send
michanne
smile Posted 2006-11-28 - 17:42     Subject: Re: Not able to sync between blackberry and memotoo
I tried it and still no go.
smile Posted 2006-11-28 - 21:52     Subject: Re: Not able to sync between blackberry and memotoo
I think I have found
Try again and tell me if it's OK
michanne
smile Posted 2006-11-28 - 22:50     Subject: Re: Not able to sync between blackberry and memotoo
Yeah!! That worked!
Thank you soooo MUCH for your help!
