Last visit: 2026-09-21 - 22:16
Problem Sync Outlook Outlook - MemotooRSS Feed
Ken
smile Posted 2015-09-07 - 23:00
There is a problem that has been there for a long time.
If you create a fresh sync with outlook all will start working normally.
Until these events happen
You have a recurring event - and you go in outlook and edit one event (not the whole series). Once you do that - that change will not get synced with Memotoo. Also from then onwards no other events created / deleted or edited in outlook will be synced to memotoo.
You will need to delete the whole sync and do it again.
This has been there for quite a while and it is really a bugger.
hope it can be fixed
Ken
smile Posted 2015-10-11 - 13:28     Subject: Re: Problem Sync Outlook - Memotoo
Can i get some feedback on this problem please?
