Last visit: 2026-09-21 - 22:15
Using memotoo across many IOS Contacts programsRSS Feed
Rhiannan
smile Posted 2015-04-29 - 18:47
Hi Memotoo Team,
I'm using Memotoo to sync my address book on several of my iOS devices. I have made a custom template for information I need to gather from my contacts (such as specific types of websites, time zones, links to reference documents).
These customised fields don't show up on all devices, and I realise now it's because they're not getting picked up by Memotoo in the first place, to then sync to other devices.
I've tried to add personalised fields in the 'other' section of Memotoo, but I don't know the right vCard / SyncML syntax to use (or if that's even the problem.
Could you please help?
Best,
Rhiannan
smile Posted 2015-04-30 - 14:48     Subject: Re: Using memotoo across many IOS Contacts programs
Hi Rhiannan
Normmally I think, if you define custom fields with the "VCARD" syntax, after theses fields will be synced.
https://www.memotoo.com/my-addressbook-and-contacts.php?rub=prefs
May be it is difficult for you to know the "VCARD" syntax for theses fields, so send me an email at webmaster@memotoo.com to help you.
