Last visit: 2026-09-21 - 22:16
Notes synching issue with Synthesis and memotooRSS Feed
Carl Eric Codere
smile Posted 2015-04-15 - 18:29
Greetings,
I am a happy paying member of memotoo, and I have been using it for several years now, I have also been using the Synthesis application on Android, especially the notes - and I seem to have found a bug - when I try to synchronize to memotoo, my notes never appear on the server side... The synthesis log states that an update on the server side is required, but it does not seem tp happen, I have 10 notes in Synthesis, but only 7 appear on the server side, would it be possible to check?
I am using synthesis 2.8.6 on Android 4.1.2
Any help would be appreciated,
smile Posted 2015-04-17 - 09:53     Subject: Re: Notes synching issue with Synthesis and memotoo
Thanks to be a happy user from many years
Strange for this problem, I will log your next sync. Can you sync again your notes and send me an email at webmaster@memotoo.com for I check your sync ?
Carl Eric Codere
smile Posted 2015-04-17 - 18:33     Subject: Re: Re: Notes synching issue with Synthesis and memotoo
It seems that updating to Synthesis to 3.2.0 solved the problem! Thanks for the help!
Carl
