Last visit: 2026-09-21 - 22:15
https not working due to a problem with CertificateRSS Feed
Darren
smile Posted 2014-11-05 - 03:23
Lately I have not been able to use memotoo app to sync my Samsung Galaxy Note 3. It works when I switch to the http address.
I downloaded the cert again, and installed it. But it still did not work.
I used CAdroid to probe the certificate, and found a problem with the certificate. The note says the "X.509 v3+ certificates may contain extensions. One of these extensions is the Basic Constraints extension. It contains a CA flag and optionally, a path length constraint. Android will only accept CA certificates when they have a CA flag set to TRUE. Otherwise, it's assumed that this CA mustn't issue certifcates, not even for itself (self-signed). The CA Flag of this certificate is not set or FALSE, so Android would import the certificate without showing an error, but it wouldn't appear in the list and wouldn't be usable."
Which probably explains why I cannot get it to work on my phone.
Help?
smile Posted 2014-11-05 - 09:13     Subject: Re: https not working due to a problem with Certificate
Hi Darren
I have updated the SSL certifcate yesterday and it does not work for some users.
So I have restored the old certificate and I will try to find the problem before install it again.
Try again to connect now it is good.
Darren
smile Posted 2014-11-05 - 17:37     Subject: Re: Re: https not working due to a problem with Certificate
Thanks! Working now.
