Last visit: 2026-09-21 - 22:52
Timezone problem with recurring eventsRSS Feed
smile Posted 2014-06-10 - 21:45
I have just enabled CalDAV sync on my Jolla. Single events are correctly displayed.
All my recurring events, however, are shifted one hour in the calendar of the phone (i.e 8 instead of 7 o'clock). My timezone is set to GMT +1 in the memotoo settings as well as on the phone.
When I sync memotoo to google calendar and use CalDAV to display the google calendar, the recurring events are not shifted one hour, but are displayed correctly. Thus, I do not think memotoo is the problem
smile Posted 2014-06-12 - 21:42     Subject: Re: Timezone problem with recurring events
Strange... Does it appear only on events that start before Summer hour (near end of march) or all ?
For example, if you add a recurrent event today each week, the hour next week is not the good one ?
adca1
smile Posted 2014-06-12 - 23:49     Subject: Re: Re: Timezone problem with recurring events
Thank you. A test recurring event starting today lasting till the end of June (daily interval) was correctly displayed.
I have then verified each of my recurring events in the light of your suggestions/hint. The result is as follows :
Recurring events starting before the end of October 2013 (i.e. before the change from DST to normal time) as well as those with a starting date after the end of March 2014 are displayed correctly.
The error reported affects recurring events with a starting date between these two dates (the "all" in my initial post was thus too generous ...- sorry).
