Last visit: 2026-09-21 - 22:52
Hotmail Sync problemRSS Feed
smile Posted 2014-06-10 - 17:43
Hello,
I am using Memotoo for several weeks now, to sync with an Hotmail Account (windows phone...), thunderbird, etc...
but I have got some troubles and I don't understand why:
- I noticed that the automatisation (ActiveSync) doesn't work properly (every 2 hours for example)
- when I add an event on my windows phone (only Hotmail account), it never syncs with Memotoo, even when I click manually on the button; but it appears on my Outlook.com account on the web, so the sync windows phone -> Outlook.com works...
how can I solve those problems?
regards
smile Posted 2014-06-12 - 21:27     Subject: Re: Hotmail Sync problem
1) Strange that the sync is not each hour, normally it is each hour if the sync has not been started since one hour...
2) When you add the event on your phone, do you add the event in the Calendar synced with Memotoo ?
fred23195
smile Posted 2014-06-13 - 19:00     Subject: Re: Hotmail Sync problem
strange again: it worked properly today: I add an event on my smartphone, and it was correctly synced on memotoo...
for the automatisation, I noticed that some times, I must go to the parameter sync menu, to check and maybe re-enter the every-hour option.
wait and see
