Last visit: 2026-09-21 - 22:52
Problem with contacts from NokiaRSS Feed
AdamS
smile Posted 2013-11-15 - 16:59
Hi, I have problem with contact sync between my Nokia E6 (E6-00 Belle) and Memotoo.
After sync in Memotoo there are NO emails in contacts.
All data like birthdays, addresses, notes are ok but emails field don't want to synchronize in contact.
Please help me. It's very important for me to have all contacts well synchronized.
7 Replie(s)
AdamS
smile Posted 2013-11-15 - 17:08     Subject: Re: Nokia 6230i Doesn't sync Address Field
In my nokia E6 the email field also doesn't sync..
smile Posted 2013-11-15 - 18:33     Subject: Re: Problem with contacts from Nokia
Hi AdamS
Strange... Can you modify a contact that have an email address and sync again ?
Il will check the log and see if the email is sent to Memotoo.
AdamS
smile Posted 2013-11-15 - 20:28     Subject: Re: Problem with contacts from Nokia
Ok. I added new user (Test Test) in my phone and made a sync.
Name: Test, Surname: Test. I filled also other fields and now I see that email & birthday field doesn't sync... This is also strange becouse in previous syncing others contacts have birthday fields synced.
Thanks for quick answer
smile Posted 2013-11-16 - 14:13     Subject: Re: Re: Problem with contacts from Nokia
Are you defined email and birthday for "Test" ?
Because I have seen that email and birthday are sent for "Anna I..."
AdamS
smile Posted 2013-11-16 - 21:13     Subject: Re: Problem with contacts from Nokia
yes. I define those fields in Test.. but also put the second mail for contact you have find. Birthdays are sync correctly - it was my fault.
I think about this and make few tests. So..
I create new contact: "Test2 Test2" with all details I can write there.
And there is problem with:
- field "nick" (Suchy) doesn't sync
- field "email" - default field in nokia doesn't sync (I wrote two mails/two field: " mail@default.pl", " mail@default2.pl")
only fields "work-email" and "home-email" has been sync correctly (" mail@home.pl", " mail@work.pl")
- field "website address" also sync only "work" and "home" but the default website doesn't sync ("www.default.pl", "www.work.pl", "www.home.pl")
- fields: kids, husband/wife, and some else also doesn't sync but this only for information becouse I don't need them.
So I hope that my test and info will be very usefull for you.
Adam
smile Posted 2013-11-17 - 15:46     Subject: Re: Re: Problem with contacts from Nokia
I can do nothing for "default" field, "nick" field and kids, husband/wife, ...
There are in the vCard sent by your Nokia:
BEGIN:VCARD
VERSION:2.1
N:Test2;Test2;Lech;Mgr
ORG:Firma2;Wydz.
TITLE:Instruktor
TEL;CELL:+48999999999
TEL;CELL;HOME:6
TEL;CELL;WORK:1
TEL:+48321111111
TEL;HOME:26
TEL;WORK:21
TEL;FAX:444
TEL;FAX;HOME:4446
TEL;FAX;WORK:4441
EMAIL;INTERNET;HOME;ENCODING=QUOTED-PRINTABLE:mail=40home.pl
EMAIL;INTERNET;WORK;ENCODING=QUOTED-PRINTABLE:mail=40work.pl
URL: http://www.default.pl
URL;HOME: http://www.home.pl
URL;WORK: http://www.work.pl
ADR:;;Polna 12/18;Katowice;Slaskie;41-600 ;Polska
ADR;HOME:;;Dom 12;Swce;;41
ADR;WORK:;;Praca;Kce;;40
BDAY:19990101
NOTE:Note
REV:20131116T212212Z
END:VCARD
Heiko
smile Posted 2014-02-14 - 17:21     Subject: Re: Re: Re: Problem with contacts from Nokia
There's no field EMAIL:INTERNET without WORK/HOME in the protocol sync from Nokia to memotoo?
Thanks!
