Last visit: 2026-09-22 - 00:17
Recurring events wrong by 1h using synchronized with CalDAV after DST changeRSS Feed
Christoph
smile Posted 2012-11-26 - 14:09
after DST-change all the recurring events are 1 h wrong when synchronizing.
In Memeto (GMT+1/Berlin):
- Event one: 9:00 - 10:00 (single event)
- Event two: 11:00-12:00 (recurring event)
In Iphone and Outlook (GMT+1/Berlin) (using CalDAV; I have to use CalDAV)
- Event one correct: 9:00 - 10:00 (single event)
- Event two not correct: 10:00-11:00 (recurring event)
Additoinal Information:
- I created both dates prior to DST change.
- Might be same error than: "Recurring events synchronized with Thunderbird got time wrong after DST change"
Best regards
Christoph
4 Replie(s)
smile Posted 2012-11-29 - 14:05     Subject: Re: Recurring events wrong by 1h using synchronized with CalDAV after DST change
Hi Chris
Sorry I can do nothing with the repeat event and with this problem of Daily Saving Time ...
You must modify them and start them in the same period of DST (March -> October and October -> March) to have the good hour ...
Karl
smile Posted 2013-03-11 - 21:12     Subject: Re: Recurring events wrong by 1h using synchronized with CalDAV after DST change
Same issue...this is the only issue that I have had using Memotoo and it is unfortunate.
Stéphane
smile Posted 2013-05-30 - 22:53     Subject: Re: Recurring events wrong by 1h using synchronized with CalDAV after DST change
This issue has been reported on Launchpad ( https://bugs.launchpad.net/ubuntu/+source/lightning-extension/+bug/984682) and a discussion on a similar problem took place on the KDE bug tracker ( https://bugs.kde.org/show_bug.cgi?id=285743). This bugs also affects me, and as a paying user of memotoo, I would like to know on which side the problem is, so that I can either fill bugs for the different software or complain more here This problem is very frustrating...
smile Posted 2013-06-04 - 15:03     Subject: Re: Recurring events wrong by 1h using synchronized with CalDAV after DST change
Hi Christoph, Karl and Stephane
Ok now the recurrent events of CalDAV sync (server and client) have now the correct time, even if the DST change
Try again and tell me if you have problem (tell me with which software it does not work)
