Last visit: 2026-09-23 - 08:56
SyncML Funambol 3.0.14 with Outlook Outlook 2003 does not work! please helpRSS Feed
istvan
smile Posted 2006-10-05 - 23:37
since hours i try to get it done. i just want to sync my memtoo with my outlook. and it does not work. neither with 2.0.34 nor with the 3.0.14 version. if i make a entry in outlook it appears in memotoo but not vice versa (only 1 or 2 times from the calendar). if i edit a outlook task in memotoo it will not change in outlook at all. and all the events and contacts that i have in memotoo are not synced to outlook.
nothing helps.
pleassse help!
Thank you
5 Replie(s)
istvanst
smile Posted 2006-10-07 - 21:13     Subject: Re: SyncML Funambol 3.0.14 with outlook 2003 does not work! please help
please any help welcome. i can not sync with outlook at all. please help
smile Posted 2006-10-09 - 01:27     Subject: Re: SyncML Funambol 3.0.14 with outlook 2003 does not work! please help
Can you try again ??
istvanst
smile Posted 2006-10-09 - 22:45     Subject: Re: SyncML Funambol 3.0.14 with outlook 2003 does not work! please help
NO does not work!
here my log
2006-10-09 22:44:30:593 - # Funambol Outlook Plug-in v. 3.0.14
22:44:30:593 [INFO] - Starting synchronization...
22:44:30:593 [DEBUG] - Enter synchronize method
22:44:30:609 [DEBUG] - Current app dir: C:\Program Files\Funambol\plug-ins\Funambol Outlook Plug-in
22:44:31:765 [DEBUG] - Enter loadOutlook method
22:44:31:796 [DEBUG] - Redim calendar, contacts, tasks, notes Properties array
22:44:31:796 [DEBUG] - items.preferences does exists. Read readPreferencesFromFile
22:44:31:828 [DEBUG] - Exit loadOutlook method
22:44:31:828 [DEBUG] - Enter checkForcedSlowSync method
22:44:31:828 [DEBUG] - Starting readAllFolders procedure
22:44:31:937 [DEBUG] - Exit checkForcedSlowSync method
22:44:31:937 [DEBUG] - Enter loadFoldersProperties method
22:44:31:937 [DEBUG] - folders.preferences does exists. Read readPreferencesFromFile
22:44:31:937 [DEBUG] - Exit loadFoldersProperties method
22:44:31:937 [INFO] - ********** CONTACTS SYNC ************
22:44:31:953 [DEBUG] - Enter function synchronization...
22:44:31:953 [DEBUG] - Reading configuration settings from the management tree
22:44:31:953 [INFO] - Synchronization URL: https://sync.memotoo.com/syncml
22:44:31:953 [INFO] - Preparing synchronization of contact...
22:44:31:953 [DEBUG] - Initialization message:
22:44:31:968 [DEBUG] -
1.1
SyncML/1.1
1160426671
1
sc-pim-outlook
b64
syncml:auth-basic
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
250000
1
200
contact
contact
1160426607
1160426671
22:44:32:000 [DEBUG] - Connecting to sync.memotoo.com:80
22:44:32:000 [DEBUG] - Requesting resource /syncml
22:44:32:437 [DEBUG] - Message sent
22:44:32:437 [DEBUG] - Reading response...
22:44:32:437 [DEBUG] - Content-length: 1155
22:44:32:437 [DEBUG] - Response read
1.1
SyncML/1.1
1160426671
1
sc-pim-outlook
https://sync.memotoo.com/syncML.php?sid=d95adb1a5b1432defdf058519fb193ba
1
1
0
SyncHdr
sc-pim-outlook
212
2
1
1
Alert
contact
contact
200
1160426671
3
200
contact
contact
1160426607
1160426671
22:44:32:453 [DEBUG] - CALLBACK: Enter prepareSyncFiles method
22:44:32:453 [DEBUG] - Enter listAllItemsInFolder method
22:44:32:453 [DEBUG] - Exit listAllItemsInFolder method
22:44:32:468 [DEBUG] - Enter listCreItemsInFolder method
22:44:32:468 [DEBUG] - Exit listCreItemsInFolder method
22:44:32:468 [DEBUG] - Enter listModItemsInFolder method
22:44:32:468 [DEBUG] - Exit listModItemsInFolder method
22:44:32:484 [DEBUG] - Enter listDelItemsInFolder method
22:44:32:484 [DEBUG] - Exit listDelItemsInFolder method
22:44:32:484 [DEBUG] - Exit prepareSyncFiles method
22:44:32:484 [DEBUG] - CALLBACK: Enter getStringNewItemsInFolderContacts method
22:44:32:484 [DEBUG] - Exit getStringNewItemsInFolderContacts method
22:44:32:484 [DEBUG] - Enter method getItemsFromFileSystem
22:44:32:484 [DEBUG] - Enter method fillItemsArrayFromFileSystem
22:44:32:484 [DEBUG] - Exit method fillItemsArrayFromFileSystem
22:44:32:484 [DEBUG] - Exit method getItemsFromFileSystem
22:44:32:484 [DEBUG] - CALLBACK: Enter getStringModItemsInFolderContacts method
22:44:32:500 [DEBUG] - Exit getStringModItemsInFolderContacts method
22:44:32:500 [DEBUG] - Enter method getItemsFromFileSystem
22:44:32:500 [DEBUG] - Enter method fillItemsArrayFromFileSystem
22:44:32:500 [DEBUG] - Exit method fillItemsArrayFromFileSystem
22:44:32:500 [DEBUG] - Exit method getItemsFromFileSystem
22:44:32:500 [DEBUG] - CALLBACK: Enter getStringDelItemsInFolderContacts method
22:44:32:500 [DEBUG] - Exit getStringDelItemsInFolderContacts method
22:44:32:500 [DEBUG] - Enter method getDelItemsFromString
22:44:32:500 [DEBUG] - Exit method getDelItemsFromString: element numItems is NULL
22:44:32:500 [DEBUG] - Modification message:
1.1
SyncML/1.1
1160426671
2
sc-pim-outlook
250000
1
1
0
SyncHdr
sc-pim-outlook
200
2
1
3
Alert
contact
contact
200
1160426671
3
contact
contact
22:44:32:500 [DEBUG] - Connecting to sync.memotoo.com:80
22:44:32:500 [DEBUG] - Requesting resource /syncML.php?sid=d95adb1a5b1432defdf058519fb193ba
22:44:37:468 [DEBUG] - Message sent
22:44:37:468 [DEBUG] - Reading response...
22:44:37:468 [DEBUG] - Content-length: 119137
22:44:38:062 [DEBUG] - Response read
22:44:38:078 [DEBUG] -
1.1
SyncML/1.1
1160426671
2
sc-pim-outlook
1
2
0
SyncHdr
sc-pim-outlook
200
2
2
3
Sync
contact
contact
200
3
contact
contact
4
105939
smile Posted 2006-10-12 - 00:58     Subject: Re: SyncML Funambol 3.0.14 with outlook 2003 does not work! please help
For the moment, sync with Outlook just work with plugin Funambol version 2.0.34:
-> https://www.memotoo.com/softs/sync4j-outlook-2.0.34.exe
Memotoo -> Outlook : OK
Outlook -> Memotoo : OK
smile Posted 2006-10-13 - 00:13     Subject: Re: Memotoo now compatible with SyncML Funambol 3.0.14 and outlook 2003
It's OK now, Memotoo is compatible with the Funambol plugin version 3.0.x:
-> Plug-in Sync4j pour Outlook: https://www.memotoo.com/softs/funambol-outlook-plugin-3.0.14.exe
-> Plug-in Sync4j pour Pocket PC / Windows Mobile PDA: https://www.memotoo.com/softs/funambol-windowsmobile-plugin-3.0.31.exe
-> Plug-in Sync4j pour BlackBerry: https://www.memotoo.com/softs/funambol-blackberry-plugin-3.0.7.zip
-> Plug-in Sync4j pour Palm: https://www.memotoo.com/softs/funambol-palm-plugin-3.0.3.zip
-> Plug-in Sync4j pour iPod: https://www.memotoo.com/softs/funambol-ipod-plugin-3.0.6.exe
