Last visit: 2026-09-22 - 01:52
iCloud calendar sync problemRSS Feed
Fabrizio Lodi
smile Posted 2012-04-14 - 21:00
When trying synching I get an error telling no calendat server to sync
contact synching works well
can someone help me?
8 Replie(s)
smile Posted 2012-04-15 - 11:44     Subject: Re: Re: iCloud calendar sync problem
Hi Fabrizio
Try again and correct the bad characters in the contact that have problem.
(now when you sync Memotoo show you the contact that have prolem)
Fabrizio Lodi
smile Posted 2012-04-15 - 16:29     Subject: Re: Re: iCloud calendar sync problem
Sorry, probably being my english not so good you misunterstood.
I don't have problems with iCloud contacts synching. Contacts sync with iCloud works great.
I have problem with Calendar synching, where I get an error that says "No server calendar to sync" (just tried right now).
Thank you
ps Memotoo is the best sync service out there!
smile Posted 2012-04-15 - 17:08     Subject: Re: iCloud calendar sync problem
Ok Fabrizio now the sync of the calendar works for you
If you like Memotoo, talk about Memotoo around you, I will really appreciate
Fabrizio Lodi
smile Posted 2012-04-15 - 17:10     Subject: Re: iCloud calendar sync problem
I spread the word everytime I can (see @fabr1z on twitter for example)
What was the problem? Something I made wrong?
smile Posted 2012-04-15 - 17:15     Subject: Re: iCloud calendar sync problem
Yes may be.
I think you add the sync and after you delete it ??
Fabrizio Lodi
smile Posted 2012-04-15 - 17:23     Subject: Re: iCloud calendar sync problem
Yes, multiple times, I wsa trying (and now thanx to you it works) to sync iclodu tasks with toodledo with google tasks. Uber Tasks!!!
marmotta
smile Posted 2012-04-27 - 22:45     Subject: Re: iCloud calendar sync problem
I have the same problem
smile Posted 2012-05-02 - 14:36     Subject: Re: iCloud calendar sync problem
marmotta, OK I have corrected the sync with iCloud for your account
