Last visit: 2026-09-22 - 02:38
Synchronization PB between Android Android (Nexus S) and Funambol - SyncMLParserExceptionRSS Feed
Happydroid
smile Posted 2011-06-15 - 14:06
Hello,
I installed Funambol a few time ago on my phone: SAMSUNG NEXUS S (Android). Every thing was fine.
Then, for personal reason, I rested my phone. Since, the synchronization doesn't work anymore. I downloaded the app on my phone, I entered (an re-re-re-checked the login information). I can login without any problem.
But then, when I want to synchronize my contacts, I got the message "Connecting..." and then "Sync failed".
I checked the log synchronization, and it seems the problem is coming from a parsing mistake:
Wed Jun 15 11:56:11 HAEC 2011 [ERROR] [SyncManager] Exception(com.funambol.syncml.spds.SyncMLParserException: Cannot parse command: org.xmlpull.v1.XmlPullParserException: expected: '>' actual: '/' (position:START_TAG (empty) @1873:125 in java.io.InputStreamReader@406349a0) )
Wed Jun 15 11:56:11 HAEC 2011 [ERROR] com.funambol.syncml.spds.SyncMLParserException: Cannot parse command: org.xmlpull.v1.XmlPullParserException: expected: '>' actual: '/' (position:START_TAG (empty) @1873:125 in java.io.InputStreamReader@406349a0)
Can it be the reason why the synchronization is failing? if yes, how to solve it? If no, any other ideas?
Thank you in advance for your answers
smile Posted 2011-06-15 - 19:07     Subject: Re: Synchronization PB between Android (Nexus S) and Funambol - SyncMLParserException
Ok I have corrected the problem
The chars "", and "&" were not accepted by the Funambol Android 10.x.
Happydroid
smile Posted 2011-06-16 - 19:10     Subject: [Resolved] Re: Re: Synchronization PB between Android (Nexus S) and Funambol - SyncMLParserException
Thanks !
