Last visit: 2026-09-22 - 02:41
syncevolution / memotoo problem with recursive meetings and daylight savingsRSS Feed
andE
smile Posted 2010-12-09 - 17:18
I have just started using memotoo (previously used scheduleworld) and noticed that recursive meetings are being incorrectly synced - they end up 1hr too early (start and end time).
It seems to be daylight savings problem.
I THINK it could be explained by WHEN the event was created:
I did not have this problem with scheduleworld and have not installed a different version of syncevolution.
My setup is:
2 personal PCs: - linuxmint+evolution+syncevolution
1 work PC: - windowsXP+outlook2003+funambol
In each case syncevolution and funambol are latest versions.
I am pretty sure the problem is with memotoo and I think it is related to not saving the timezone with the event - or at least not passing it onto the clients. e.g. when I do a download in iCal format there is no timezone entry. Same as the data that arrives at syncevolution - i.e. no TZID is sent - and yet I see in the outlook appointment the timezone information is there.
So, when will we get a fix?
Thanks!
5 Replie(s)
r_mano
smile Posted 2010-12-10 - 13:43     Subject: Re: syncevolution / memotoo problem with recursive meetings and daylight savings
I have exactly the same problem. "Old" recurring events (set when DST was in force) have the same problem. I think this is very important to fix.
Please?
PD I think that all this story about timezones in the calendar is bogus. I would simply suppress it. My calendar is in the timezone that I happen to be, so if I set something form 9am to 11am, it's just that, from 9am to 11am, why mess? I understand this is not a memotoo problem, is in the spec, but...
smile Posted 2010-12-11 - 10:57     Subject: Re: Re: syncevolution / memotoo problem with recursive meetings and daylight savings
Ok I have found a solution to show the good hour for the reccurent events that are repeat on different DST
So synchronize again the event and it will be OK.
r_mano
smile Posted 2010-12-12 - 10:51     Subject: Re: syncevolution / memotoo problem with recursive meetings and daylight savings
It seems that the problem is fixed with syncevolution, but is still here when syncing with google calendar...
Anyway, thanks for the fix. I hope the other half will be as fast as this!
andE
smile Posted 2010-12-12 - 12:26     Subject: Re: syncevolution / memotoo problem with recursive meetings and daylight savings
yes seems to work now with syncevolution (needed to set refresh-from-server).
I don't use google calendar so for me the case is closed but I guess others need google.
THANKS!!!!
andE
r_mano
smile Posted 2010-12-15 - 11:45     Subject: Re: syncevolution / memotoo problem with recursive meetings and daylight savings
Now google calendar is fixed too! Thank a lot!
