Last visit: 2026-09-22 - 03:14
Syncing Memotoo with Funambol server: problem with portable numberRSS Feed
Massimo
smile Posted 2010-10-19 - 19:52
Hello everybody,
i have synced memotoo's contacts with a Funambol server (8.5.2), but i noticed the portable numbers are not be in the Funambol, altough the others values were correctly synced.
How can i resolve this?
Best Regards
9 Replie(s)
François-Jean
smile Posted 2010-11-08 - 18:25     Subject: Re: Syncing Memotoo with Funambol server: problem with portable number
I have the same problem with blackberry sync 8.7.3 version !
Any solution ????
smile Posted 2010-11-17 - 16:21     Subject: Re: Re: Syncing Memotoo with Funambol server: problem with portable number
The Funambol plugin for BlackBerry can sync only one mobile number...
If you want sync the mobile home and mobile work, use the Nexthaus plugin.
Massimo, are you still sync your Funambol server ?
Massimo
smile Posted 2010-11-24 - 21:13     Subject: Re: Re: Syncing Memotoo with Funambol server: problem with portable number
Hello Thomas,
i have made a test, a have created a new contact in Memotoo and a new one in my Funambol server ( joined to Simple Groupware http://www.simple-groupware.de/cms/InstallationSyncML) and then synced.
The contact made in Funambol there is not in Memotoo, and the one made in Memotoo is in Funambol!
The problem is that not all the fields are synced and the ones synced are not of one group (home, work or other)
the fax in Funambol is joined with the fax home in Memotoo (and not with work), the mail in Funambol is synced with the mail other in Memotoo (and not with work).
I think the problem is in my Funambol server, so i have to create new fields in my server and then join in the right mode with Memotoo.
Now two questions:
1) why in Memotoo there is not my contact made in my Funambol server?
2) Do you know if there is some documentation to resolve the problem in my Funambol server?
Best Regards
Massimo
Massimo
smile Posted 2010-11-30 - 18:15     Subject: Re: Syncing Memotoo with Funambol server: problem with portable number
Hello Thomas,
i have find the code that Funambol use to join the contact and the telephone number ( https://core.forge.funambol.org/ds/getDSMessageAttachment.do/Funambol%20PIM%20Ca...), per example the main mobile phone number is 3.
My question is: the cellular phone business and the other, are linked to which number in synchronization with a SyncML server?
Best Regards
Massimo
smile Posted 2010-12-01 - 14:22     Subject: Re: Syncing Memotoo with Funambol server: problem with portable number
Hello Massimo
Can you try again to modify the 2 contacts (the one added on Memotoo and the one added on your Funambol server) -> I will log the synchronization to see what is wrong and the synctax.
Tell me when you have done this ?
Here the syntax that Memotoo send to your Funmabol server to synchronize cellular phone:
TEL;HOME;CELL:xxxxx
TEL;CELL:xxxxx
TEL;OTHER;CELL:xxxxx
Massimo
smile Posted 2010-12-01 - 21:28     Subject: Re: Syncing Memotoo with Funambol server: problem with portable number
Hello Thomas,
i have sync some minutes ago my Funambol server and Memotoo.
I can see in the Funambol server the contacts that were present in Memotoo, but i can not see the only one contact present in the Funambol server...
Can you see?
Best Regards
Massimo
Massimo
smile Posted 2010-12-01 - 21:37     Subject: Re: Syncing Memotoo with Funambol server: problem with portable number
Hello,
to be more clear i can find in my fnbl_pim_contact_item only this values joined to the new contact created in Memotoo like test:
3265;1;"Telefono Memotoo casa"
3265;2;"Fax Memotoo casa"
3265;3;"Cellulare Memotoo casa"
3265;4;"Indirizzo e-mail casa"
3265;5;" http://www.lavoro.it"
3265;6;" http://www.casa.it"
3265;7;" http://www.lavoro.it"
3265;10;"Telefono Lavoro Memotoo"
3265;11;"Fax Lavoro Memotoo"
3265;13;"Telefono dell'assist"
3265;14;"Telefono auto Memoto"
3265;16;"E-mail lavorativa Lavoro Memotoo"
3265;20;"Cercapersona Memotoo"
3265;23;"E-Mail Altro Memotoo"
3265;29;"Fax Altro Memotoo"
3265;30;"Telefono Altro Memotoo"
3265;31;"Cellulare Lavoro Memotoo"
Like you can see, i do not find "Cellulare altro Memotoo"
I hope this can help.
Massimo
smile Posted 2010-12-03 - 14:22     Subject: Re: Syncing Memotoo with Funambol server: problem with portable number
Hello Massimo
Can you try again to synchronize? I have done a modification.
For the fields, the field "Cellulare altro Memotoo" could not be synced because there is no field for this with the format "text/x-s4jsifc":
<contact>
<AssistantName></AssistantName>
<AssistantTelephoneNumber></AssistantTelephoneNumber>
<Birthday></Birthday>
<Body></Body>
<BusinessAddressCity></BusinessAddressCity>
<BusinessAddressCountry></BusinessAddressCountry>
<BusinessAddressPostalCode></BusinessAddressPostalCode>
<BusinessAddressState></BusinessAddressState>
<BusinessAddressStreet></BusinessAddressStreet>
<BusinessFaxNumber></BusinessFaxNumber>
<BusinessTelephoneNumber></BusinessTelephoneNumber>
<Business2TelephoneNumber></Business2TelephoneNumber>
<CarTelephoneNumber></CarTelephoneNumber>
<Categories></Categories>
<Children></Children>
<CompanyName>Basko spa</CompanyName>
<Department></Department>
<Email1Address></Email1Address>
<Email1AddressType>SMTP</Email1AddressType>
<Email2Address></Email2Address>
<Email2AddressType>SMTP</Email2AddressType>
<Email3Address></Email3Address>
<Email3AddressType>SMTP</Email3AddressType>
<FileAs></FileAs>
<FirstName></FirstName>
<HomeAddressCity></HomeAddressCity>
<HomeAddressCountry></HomeAddressCountry>
<HomeAddressPostalCode></HomeAddressPostalCode>
<HomeAddressState></HomeAddressState>
<HomeAddressStreet></HomeAddressStreet>
<HomeFaxNumber></HomeFaxNumber>
<HomeTelephoneNumber></HomeTelephoneNumber>
<JobTitle></JobTitle>
<LastName></LastName>
<ManagerName></ManagerName>
<MiddleName></MiddleName>
<MobileTelephoneNumber></MobileTelephoneNumber>
<NickName></NickName>
<OtherAddressCity></OtherAddressCity>
<OtherAddressCountry></OtherAddressCountry>
<OtherAddressPostalCode></OtherAddressPostalCode>
<OtherAddressState></OtherAddressState>
<OtherAddressStreet></OtherAddressStreet>
<OtherFaxNumber></OtherFaxNumber>
<OtherTelephoneNumber></OtherTelephoneNumber>
<PagerNumber></PagerNumber>
<Spouse></Spouse>
<Subject></Subject>
<Suffix></Suffix>
<Title></Title>
<WebPage></WebPage>
<HomeWebPage></HomeWebPage>
</contact>
-> May be use the format: "text/x-vcard"
Massimo
smile Posted 2010-12-05 - 19:32     Subject: Re: Syncing Memotoo with Funambol server: problem with portable number
Hello Thomas,
i have modified the two contacts, the ones used for the test purpose, and synced again.
In my Funambol server i have found the one modified in Memotoo, but i can not still find the one of Funambol.
Cognome
Last name Funambol
Nome
first name Funambol qwerty
id contatto
Display_Name_Funambol
Società
Company Funambol
Posizione
Job Title Funambol
E-mail
E_mail_Address_ Funambol@me.it
Telefono
Business Phone Funambol
descrizione
body
categoria
categories
Thanks for your explanation, i will study how to resolve.
Best Regards
Massimo
