Last visit: 2026-09-22 - 03:14
Recurring events Outlook Outlook plugin problemRSS Feed
gray
smile Posted 2010-09-22 - 08:44
Hi.
While testing memotoo calendar I found a problem with outlook synchronization. When I set recurrence for task or event in outlook (e.g. every 5 days), memotoo calendar always saves it as recurring every day. Is anybody having same problem? Do you know solution for this bug?
gray
smile Posted 2010-09-23 - 16:08     Subject: Re: Re: Recurring events outlook plugin problem
Hi gray
Ok this problem is corrected, now the repeat daily will work fine
gray
smile Posted 2010-09-24 - 09:45     Subject: Re: Recurring events outlook plugin problem
Confirm
Thank you for the quick response!
gray
