Last visit: 2026-09-22 - 04:42
Problems syncing Nokia E65RSS Feed
Alex
smile Posted 2009-04-09 - 21:44
since several days I'm having problems syncing my Nokia E65. I'm getting an "invalid host address".
What happens ist:
- connecting
- sending calendar 5 of 5
- disconnecting
- invalid host address
In fact the cell phone can connect to https://sync.memotoo.com/syncml (checked with the browser).
Do you have any idea what goes wrong?
thanks
best regards,
Alex
29 Replie(s)
smile Posted 2009-04-10 - 11:24     Subject: Re: Problems syncing Nokia E65
Hi Alex
The problem come from bad characters in a note on your mobile.
Verify the note "http://www.topografix.com/GPX/1/1" ..." and modify it or delete it.
Oddity8
smile Posted 2009-06-11 - 10:26     Subject: Re: Problems syncing Nokia E65
I got about the same problem. Only in my case it says "Sending Contacts 1 of 285" for about 30 seconds before I get the error message "Invalid host address".
I checked my notes on invalid characters like mentioned above, but no luck!
Can you help me with this? Is some other data invalid?
smile Posted 2009-06-12 - 14:21     Subject: Re: Re: Problems syncing Nokia E65
Can you try again to sync ?
I will log synchronization and see what is wrong...
Oddity8
smile Posted 2009-06-12 - 14:33     Subject: Re: Problems syncing Nokia E65
I just tried to sync and get the same message.
Hopefully you can get some usefull information out of the log.
smile Posted 2009-06-12 - 14:47     Subject: Re: Problems syncing Nokia E65
I see nothing wrong ...
Can you sync again, I want to see if the error is always in the same contact ??
Oddity8
smile Posted 2009-06-12 - 14:52     Subject: Re: Problems syncing Nokia E65
I tried it again, twice. Once via a normal connection, and once via a secured (SSL) connection.
Both of the times i get the same message: "Invalid host address" after 30 seconds of "Sending Contacts 1 of 285"
smile Posted 2009-06-15 - 17:22     Subject: Re: Re: Problems syncing Nokia E65
I have found nothing wrong for the moment ...
Can you try again to sync ? (I want to see the WBXML syntax if there is something wrong)
Oddity8
smile Posted 2009-06-15 - 19:49     Subject: Re: Problems syncing Nokia E65
Tried it again, but unfortunately the same result gain.
smile Posted 2009-06-16 - 18:40     Subject: Re: Problems syncing Nokia E65
I think I have found
Can you try again to sync ???
Oddity8
smile Posted 2009-06-17 - 08:15     Subject: Re: Problems syncing Nokia E65
I really do hope you found it.
At your request I just tried it again. (With the same result/message)
smile Posted 2009-06-17 - 10:30     Subject: Re: Problems syncing Nokia E65
Can you try again ?
I have change an other thing but I think it will not better ...
Oddity8
smile Posted 2009-06-17 - 11:13     Subject: Re: Problems syncing Nokia E65
I tried to sync again, but you were right. No improvement yet.
smile Posted 2009-06-17 - 16:13     Subject: Re: Problems syncing Nokia E65
Ok ... This time I think it will work
I hope a good new from you
Oddity8
smile Posted 2009-06-17 - 16:27     Subject: Re: Problems syncing Nokia E65
I hate to disappoint you, so I will try to keep it to a minimum.
There is SOME improvement. I still get the same error message ("Invalid host address") only this time it seemed 20 contacts were sync'ed before I got the message.
It reached "Sending Contacts 20 of 285", but then it waited for about 30 seconds again until the error popped up.
Has it something to do with the data of my contacts? Is there something I should check or change?
smile Posted 2009-06-17 - 16:45     Subject: Re: Problems syncing Nokia E65
May be a contact has a problem because it's on the same there is an error...
But can you try again ??? I want to test an other thing ...
Oddity8
smile Posted 2009-06-17 - 19:39     Subject: Re: Problems syncing Nokia E65
I tried to sync again.
Same message as last time (after 20 contacts).
smile Posted 2009-06-18 - 12:01     Subject: Re: Problems syncing Nokia E65
Can you try to delete the photo of "Hotel 1900" and sync again ?
Oddity8
smile Posted 2009-06-18 - 12:09     Subject: Re: Problems syncing Nokia E65
I removed the photo, and tried to sync again. But no luck this time either.
Stille the same message after 20 contacts.
smile Posted 2009-06-18 - 14:04     Subject: Re: Problems syncing Nokia E65
Ok ...
Can you try an other sync whitout SSL ? I want log the synchronization.
Oddity8
smile Posted 2009-06-19 - 08:03     Subject: Re: Problems syncing Nokia E65
I tried again, but it is worse. It looks like it cannot find the server at all.
I can see no "Sending contacts" message but get an error message at once ("Invalid host address")
furthermore, I cannot open the My Addresses site either. After logging in on the main Memotoo site I get the following message:
"Parse error: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING, expecting ')' in /var/www/memotoo/web/inc/fonctions_contacts.inc.php on line 3200"
I don't know whether these problems might be associated with each other.
smile Posted 2009-06-19 - 09:08     Subject: Re: Problems syncing Nokia E65
Sorry for this bug, try again it's OK now.
Theses 2 problems are not associatied. The error "Parse error: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING, expecting ')' in /var/www/memotoo/web/inc/fonctions_contacts.inc.php on line 3200" was a little bug in my script.
So can you try again to sync ?
Oddity8
smile Posted 2009-06-19 - 12:09     Subject: Re: Problems syncing Nokia E65
About the last problem: I can properly login to and open the memotoo site and My Addresses again
About the sync'ing problem: again no luck, after 20 contacts I again get the message "Invalid host address"
smile Posted 2009-06-19 - 12:23     Subject: Re: Problems syncing Nokia E65
It's normal there is no progress because I must found why this problem.
This time can try to sync just one time ?
I want to log the complete sync.
Oddity8
smile Posted 2009-06-19 - 13:03     Subject: Re: Problems syncing Nokia E65
I just retried it. A single sync via normal (no SSL) connection.
Hopefully you'll find something.
smile Posted 2009-06-19 - 14:22     Subject: Re: Problems syncing Nokia E65
I'm very surprised what I see !
Memotoo don't respond to the 3rd trame because may your mobile send trame with a "HTTP/1.1 100 Continue" response. Before I thinked that the problem came from the 2nd trame...
Now I know where is the problem, but I'm not sure how to correct it.
Can you try again, we test something ?
Oddity8
smile Posted 2009-06-19 - 15:09     Subject: Re: Problems syncing Nokia E65
Sure, we can test something.
I just tried to sync again...
Oddity8
smile Posted 2009-06-29 - 13:17     Subject: Re: Problems syncing Nokia E65
I guess you love to hear my problem is solved (for now).
I just read a post of Flemming Nielsen (see https://www.memotoo.com/forum/msg-4-3215-Problem-syncing-GIF-images.html#message...) about contact photos in GIF format which troubled the synchronization process. After replacing all my contact photos in GIF format with photos in PNG format the synchronization has completed successfully.
I still hope that you do find the real underlying problem here, but at least this 'solution' should point you in the right direction.
regards!
smile Posted 2009-07-01 - 15:33     Subject: Re: Problems syncing Nokia E65
Ok good news
Lenny
smile Posted 2009-10-07 - 21:03     Subject: Re: Problems syncing Nokia E65
The issues is still arround I typed a note on the subway and when I got off I could not sync till I deleted the note. I am using a Nokia E71 Unlocked.
