Last visit: 2026-09-22 - 04:42
Task sync problemRSS Feed
Paul
smile Posted 2008-11-13 - 18:00
been using this for a few days now and liked it enough to sign up for 18 months. However I do have one problem. When I sync with my Windows Mobile device using the Funambol 7.0.8 Plug-In it will only sync my todo list from the device to memotoo, not from memotoo to my device. If I make changes on memotoo todo list they are not shown on my device. Can anyone help?
Thanks.
13 Replie(s)
smile Posted 2008-11-14 - 12:01     Subject: Re: Task sync problem
Hi Paul
Can you try to modify a task on Memotoo and sync ?
I will log connexion and see what happen. Tell when you have synced.
Paul
smile Posted 2008-11-14 - 12:05     Subject: Re: Task sync problem
Thanks. I have just added a task and done the sync.
smile Posted 2008-11-17 - 14:17     Subject: Re: Task sync problem
Ok can you try again to sync ??
Paul
smile Posted 2008-11-17 - 14:38     Subject: Re: Task sync problem
done another sync but still the same. It does show that it is syncing tasks in Fubnambol (looks like it is recieving them), but they do not show up in the todo list on windows mobile. Could it be a setting on my device?
smile Posted 2008-11-17 - 15:27     Subject: Re: Task sync problem
In fact, Funambol for Windows Mobile don't accept tasks sent by Memotoo ...
I try to find the good syntax... Can you try again to sync ??
Paul
smile Posted 2008-11-17 - 15:41     Subject: Re: Re: Task sync problem
OK, sync done . Thanks
smile Posted 2008-11-18 - 10:06     Subject: Re: Task sync problem
New sync ?
Paul
smile Posted 2008-11-18 - 10:52     Subject: Re: Task sync problem
Another sync done. Still looks like it is doing it but todo's not showing up. I appreciate your efforts on this thanks.
smile Posted 2008-11-18 - 12:20     Subject: Re: Task sync problem
Can you add a task on your mobile ? and sync ?
I will see the syntax sent.
Paul
smile Posted 2008-11-18 - 12:49     Subject: Re: Task sync problem
Added a todo called "Test task for syntax". Sync done.
Thanks.
smile Posted 2008-11-19 - 09:42     Subject: Re: Task sync problem
Ok thank, I have modified the tasks to send as the task received.
So now normally it's work but I don't understand what Windows Mobile don't want ...
Can you confirm it's OK. If not I have no others ideas ... May be there is a bug with task and "Funambol plugin for Windows Mobile 7.0.8"
Paul
smile Posted 2008-11-19 - 15:54     Subject: Re: Re: Re: Task sync problem
Thanks Thomas. Still not working but I think that this is a device issue. The plugin shows that it is downloading 5 tasks each time but they are not showing up. If I do all of my task editing on my device those changes do go through to Memotoo, so I shall do things that way.
Thanks for all the help, I will investigate the device side and see what happens.
zachofalltrades
smile Posted 2008-12-26 - 16:10     Subject: Re: Re: Task sync problem
I am having the same problem-- I have a Windows Mobile ( 6.1 WM Pro) device and have tried both Funambol 7.08, and 7.02 -- both versions fail to add/update tasks on my device, even though it appears to be working when you watch the status messages in the Funambol client. If I create a task on the device though, it does get added at MemoToo. I would be willing to pay for a functional client -- but as far as I know, Funambol is the only one that supports all of: calendar, task, contact (including photos), notes, and briefcase.
