Last visit: 2026-09-22 - 04:42
Syncing ProblemsRSS Feed
Hullabaloo
smile Posted 2008-10-29 - 01:43
Hello,
I am using Thunderbird with Linux (2.0.0.17 (20080914) with Lightning 0.9) and am trying to sync my contacts and calendars with memotoo but I have several problems to solve.
a) I can not synchronize a Calendar using the SoGo Connector. After I type in my credentials when trying to login nothing happens. I tried version 0.81 which is linked in Memotoo and the current release.
b) When using the Funambol Plugin to sync the addressbook the birthdays are not imported into Thunderbird and Work email are saved as primary email. The original primary address gets lost.
c) When I use the TSync some phone numbers get lost.
I just want to have an up to date addressbook and calendar with all fields I have in Memotoo. Is there anything I am missing?
6 Replie(s)
smile Posted 2008-10-29 - 11:10     Subject: Re: Syncing Problems
Hello Hullabaloo
Ok I have modified Memotoo to be compatible with Sogo Connector 0.9 to sync address book
So try again, now it will be OK. You will see too the "work email" will be in primary email and if the contact hasn't "work email" the primary email will be the "perosnal email".
Sorry you can't have the birthdays with the Funambol Plugin, if you want birthdays in the calendar Lightning use the link iCalendar.
More infos here: https://www.memotoo.com/how-to-sync-your-calendar-icalendar.php
Hullabaloo
smile Posted 2008-10-30 - 15:32     Subject: Re: Syncing Problems
yes thanks, I now can see my contacts. Unfortunately the Images and Birthdays are still not visible. I installed an addon for thunderbird (MoreFunctionsForAddressBook 0.5.3) that can display a birthday within the contact details. Is there anything you can do about that?
gr54
smile Posted 2008-10-30 - 23:45     Subject: Re: Syncing Problems
I had the same syncing problem with sogo, and it's now solved
But just a notice, thomas : the behavior that you describe is not that happens. the pro email is the primary in thunderbird if there is one, but when there's no pro address, the personal address is displayed twice in the primary and alternative email field in thunderbird. is it normal?
And sometimes, when i modify a field for an existing contact in thunderbird address book, the contact is displayed in duplicate, until i manually force the sync. it could be a bug in sogo connector, couldn't it?
Sorry to introduce in your post with a different question, Hullabaloo
Hullabaloo
smile Posted 2008-10-31 - 09:20     Subject: Re: Syncing Problems
No problem, I have the same issues with the connector.
Besides as I can see in my contacts the birthday is imported but the whole date is stored in the year-filed
smile Posted 2008-10-31 - 15:43     Subject: Re: Syncing Problems
Hello Hullabaloo and gr54
I can do nothing for the birthday because I think there is a bug with "MoreFunctionsForAddressBook", this extension can't import birthday value. I have tried some tests and no proddibility.... May be contact "MoreFunctionsForAddressBook" ?
Yes it is normal to have the personnal email in the fields (primary and alternative email) because it's a tip to do not have a message when "primary email" is empty.
I understand it's a little strange
gr54
smile Posted 2008-11-01 - 01:06     Subject: Re: Syncing Problems
And for the temporary duplicate contacts in address (see my previous post, you've probably missed these lines), is there a solution or is it a bug of sogo connector?
