Last visit: 2026-09-23 - 07:43
Nokia 2630 SyncML does not workRSS Feed
Hendrik
smile Posted 2008-01-19 - 18:08
Trying to sync a Nokia 2630 device via syncml over GPRS with memotoo does not work. Gives an error like "Data transmission not possible". has nothing to do with the connection, because the sync attempt get logged properly by the memotoo sync engine viewable in Sync history.
Any clues?
Thanks
Hendrik
4 Replie(s)
smile Posted 2008-01-21 - 21:50     Subject: Re: Nokia 2630 syncml does not work
Hello
Try again to sync I will log connexion and see what happen ...
Hendrik
smile Posted 2008-02-04 - 21:19     Subject: Re: Nokia 2630 syncml does not work
Have you done something? Still not working
Regards
Hendrik Saly
smile Posted 2008-02-05 - 19:25     Subject: Re: Nokia 2630 syncml does not work
For the moment I have no idea ...
Have you test with other SyncML website ???
Hendrik
smile Posted 2008-02-07 - 11:07     Subject: Re: Nokia 2630 syncml does not work
Yes, i have synced successfully against O2 syncml Server.
