Last visit: 2026-09-23 - 07:44
Fax as Home - Cell and Home not...RSS Feed
Stefan (User "stuwi")
smile Posted 2007-07-04 - 15:17
Hello
sync from cellphone (Sony K750i) worked fine with syncml
but when I make a change in memotoo in a adress the home and cellphone numbers are not there anymore in the cellphone contacts!!! But the fax number is displayed as Home number!
What is wrong
11 Replie(s)
smile Posted 2007-07-04 - 18:38     Subject: Re: Fax as Home - Cell and Home not...
Hello
It's just a thing to configure on Memotoo ...
Can you try again, I will log connexion to see what happen. Tell me when it's Ok ???
stuwi
smile Posted 2007-07-04 - 18:50     Subject: Re: Fax as Home - Cell and Home not...
made..
1 upload - ok
1 download - problem
Thank you for config
Stu
smile Posted 2007-07-04 - 19:17     Subject: Re: Fax as Home - Cell and Home not...
To understand, in your phone where are theses data ?? what fields ???
Phone:111222
Mobile Phone:222333
Fax:333
Adresse:+41 76 458 97 38 +41 32 313 33 04
stuwi
smile Posted 2007-07-04 - 20:11     Subject: Re: Fax as Home - Cell and Home not...
still the same...
Fax as Home
Cell and Home nowhere
Adress nowhere to (is only reminder in this example)
made an other test:
333 as Home
555 as business
666 as Fax
999 as Other
Mobile?????
Thank you for service
... will there be a german translation? are you interested in translation-work? I'm programmer and unterstand also french (my wife is swiss-french)
smile Posted 2007-07-04 - 20:44     Subject: Re: Fax as Home - Cell and Home not...
Good, but to find the best syntax for your mobile, can you add a contact on your mobile with all possible field: (and sync)
- phonehome
- mobilehome
- faxhome
- phonework
- mobilework
- faxwork
- phoneother
- mobileother
- faxother
Ok if you want to translate French file, I can send you by e-mail.
I think it's a big work ...
stuwi
smile Posted 2007-07-04 - 21:10     Subject: Re: Fax as Home - Cell and Home not...
tried to do so in the sync before the last (what did you see in the protocol)... but there was no result (number) at all in my mobile phone.
Thats the reason I was working with the numbers after (same order like your syntax but with 111 - 999)... and the result were like I said in the post before.
Translation: If you can spend a free account for me and my wife for a few... What do you think? Let me see the translation-file!
Thank you and until tomorow!?!
smile Posted 2007-07-05 - 18:48     Subject: Re: Fax as Home - Cell and Home not...
Add a contact with theses fields on your mobile and sync
I send you the French file by e-mail...
stuwi
smile Posted 2007-07-05 - 21:13     Subject: Re: Fax as Home - Cell and Home not...
ok... did understand now...
mobile: 111
home: 222
business: 333
Fax: 444
Other: 555
sorry no text possible...
Thank you
smile Posted 2007-07-06 - 18:07     Subject: Re: Fax as Home - Cell and Home not...
Normally it's OK
stuwi
smile Posted 2007-07-06 - 18:56     Subject: Re: Fax as Home - Cell and Home not...
still the same... extended the entries from 3 to 4 numbers on memotoo and mad a sync
only the 5555 came back to the mobile as "Home Number"...
what now? ... allready lost 3 or 4 numbers ...
smile Posted 2007-07-07 - 08:55     Subject: Re: Fax as Home - Cell and Home not...
You have just sync user "Test".
Ok I found the bug, now it's good. Modify "Test" on Memotoo and sync.
