Last visit: 2026-09-21 - 22:52
CalDAV sync problem with RainlendarRSS Feed
fred23195
smile Posted 2014-04-28 - 23:02
hello,
I've got some troubble to sync Rainlendar with Memotoo or directly with Windows Live Mail.
before looking at Rainlendar problem, I wonder if it's come from Memotoo link...
when I enter caldav parameter " https://sync.memotoo.com:443/calDAV/" with my username and password, a wrong message tells me that it can't find the good calendar.
and when I enter a category, it seems that it works, some events appear, but there is "[UNREGISTERED]" before all name...
I tried other URL I found, but they don't work again.
is someone else use Rainlendar?
could you have an idea?
regards
fred23195
smile Posted 2014-04-28 - 23:23     Subject: Re: caldav sync problem with Rainlendar
other point that would be great to solve this problem, because my local computer don't have an internet connexion every time:
is there a way / software that automaticly synchronise a local file .ics with Memotoo?
smile Posted 2014-05-04 - 19:37     Subject: Re: Re: caldav sync problem with Rainlendar
I think do not use CalDAV sync in Rainlendar, and prefer iCalendar sync with this URL:
https://sync.memotoo.com/calendarICS.php
I do not know software that send the ics automatically to Memotoo when you connect again to Internet...
fred23195
smile Posted 2014-05-04 - 19:55     Subject: Re: caldav sync problem with Rainlendar
thanks for your answer.
yes, I finally succeded in syncing with rainlendar by using ICS link: it works.
but no way to sync with a local ics file...
it would be great.
