Last visit: 2026-10-16 - 07:16
signal too weak for syncRSS Feed
Dan-cer
smile Posted 2013-07-01 - 13:37
Hi!
Just got a new smartphone with android. Trying to synchronize with the installed memotoo-sync - app failed because "signal too weak". That happened only with one of my 2 sim-cards. The first one - o2 - is working ok with sync memotoo.
The second one - simquadrat / eplus - is working fine with normal internet browsing, but refuses to syncronize because of too weak signal.
Any idea about this?
4 Replie(s)
smile Posted 2013-07-01 - 14:30     Subject: Re: signal too weak for sync
Sorry I have no idea ...
The signal of your Internet connection is fine with the second card ?
Dan-cer
smile Posted 2013-07-01 - 14:34     Subject: Re: signal too weak for sync
Yes, it is fine, will say its the same strengh in both.
Dan-cer
smile Posted 2013-07-01 - 23:00     Subject: Re: signal too weak for sync
Now I tried the other sync-tool: synthesis pro, trial version. This tool is working on the second sim (simquadrat), on which the recommended "memotoo sync" is giving the signal-error-message.
But synthesis pro isn't freeware, and I hope, memotoo sync will work as well!
Dan-cer
smile Posted 2013-07-02 - 23:08     Subject: Re: signal too weak for sync
After being in town - with high level of signal strengh - the error-message came again. Most probably it is a trouble with the provider-net. So I opened a new thread asking for a sync-tool to sync with the pc-suite of samsung instead with mobile itself.
